Question about Brother LS-2125 Mechanical Sewing Machine
I need to know how to thread a bobbin? - Brother LS-2125 Mechanical Sewing Machine
    Scholar:
  • 76 Answers
TRY THIS, itma not be your model, but should help Title:
How do I wind the bobbin? i need to know how to thread a bobbin? - windingbobbin_02.jpg
Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
Make sure that the thi need to know how to thread a bobbin? - c_b4.jpgses under the pre- tension disk.
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin ai need to know how to thread a bobbin? - windingbobbin_a0998.jpghe machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equii need to know how to thread a bobbin? - windingbobbin_a0999.jpgp button).
Caution Make sure you foli need to know how to thread a bobbin? - windingbobbin_a18.jpgcarefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controi need to know how to thread a bobbin? - windingbobbin_a19.jpg set the speed to fast).
(For models equipped with the sewing speed controller.) ac0992.jpg Sewing speed controller
10. Press the foot controlleri need to know how to thread a bobbin? - windingbobbin_a192.jpgutton (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Posted on Sep 03, 2009
5 Suggested Answers
6ya staff
SOURCE:
Tricia Cox
  • 3 Answers
SOURCE: threading
It's hard to describe such a process to someone, but a quick internet search would get you something like this to help you out: http://www.ehow.com/how_5839_thread-sewing-machine.html
Posted on Jul 25, 2007
Anonymous
  • 46 Answers
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Posted on Sep 02, 2008
Anonymous
SOURCE: how do i thread the bobbin
I have a new sewwing machine Eurp-pro Shark automatic but I don't know to thread the bobbin
Posted on Oct 11, 2008
alex_marge
SOURCE: How do I get an instruction manual for Contessa
I have this manual if you want some pages sent by e-mail let me know.
Posted on Sep 13, 2010
Need help adjusting the lower tension on my Viking sewing machine. Lower tension causes strait stitches; upper tension (zigzag) adds bunches of thread. I don't know where to adjust tensions. Help.
Generally, bobbin tension is set at the factory and is usually a "last attempt" to alter. Sounds like you are probably experiencing bird nesting or thread nesting which is a top thread issue.
Be sure to install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top thread.
Set the top tension to the mid-point and retest your machine.
Tension is correct when top and bobbin threads meet in the middle of the fabric. It is a tug of war between the two threads. When there is equal pull, the top thread pulls the bobbin thread up and the bobbin thread pulls the top thread down. Increasing the top tension pulls the bobbin thread further up, decreasing top tension will allow the bobbin thread to pull the top thread down.
Understanding Thread Tension Threads
Jan 27, 2018 | Sewing Machines
How do I thread the bobbin of a brother xr-35
fit the bobbin into the bobbin case and feed the thread to the outside through the opening. it does not matter which way round the bobbin is in the case, then insert the case into the machine make one turn with the macine so that the threaded needle drops through the plate. when it comes back up it should pull up the bobbin thread with it. then take the two threads and pull them back and insert your material to be sewn.
I hope this was useful.
Feb 12, 2015 | Brother Sewing Machines
Using metallic thread, metallic needle. Bobbin case will not engage bobbin to bring up thread to needle. Bobbin is in correctly.
When using this slippery thread it is possible you need to change things a little. To change I mean you will have to stay with a straight stitch and place your needle at the left side of the plate. It may need to be placed on the right if the hook is rotating the opposite direction. Give it a try both ways to see which way works better. Anyway, you will need to stay with a straight stitch. When you first attempt to bring your bobbin thread up you need to hold on to the upper thread.
Dec 01, 2014 | Janome Janoe Deco Coputer 2011 DC2011
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Need to know how to properly thread , the problem is once we start to sew it moves a little then stops thread tangles on bobbin and breaks from top. we try different ways of threading
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
Mar 08, 2011 | Euro-Pro 473
Bobbin thread is comming all the to the top
I know this sounds like an insult, but check FIRST to be sure you have the bobbin inserted in the bobbin case correectly. If it IS in the case right, then check your upper tension. It generally needs to be at 3. Check also to be sure the top thread is between the tension disks. If it isn't, you won't have the right tension to connect the threads. You bobbin also needs to be wound tightly. A loose wind will cause problems with the bobbin thread. If none of these work, the bobbin tension might need to be adjusted by a professional. I hope one of my suggestions helps. If so, please let Fixya know by rating my solution.
Nov 23, 2010 | Singer Featherweight 132Q Mechanical...
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
How do i thread the bobbin
Oct 07, 2008 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
339 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
