I've set up my voicemail with a personal greeting and a name greeting, but when receiving a call my phone never goes to voicemail.....just continues to ring until someone answers it. I have the 5220 IP Phone.
Call needs forwarded to voicemail. On mitel 3300 this is programmed in one in the call handling/ call rerouting for depending on the software version. First alternative should be set for voicemail route. If you have a mitel 200 you can do this through the superkey on the phone. Set no answer and if busy to the voicemail hunt pilot numbet.
You will need your system administrator to change the call reroute assignment of your phone, or you have call forwarding active to a location the system can not route a call to. Either scenario your phone administrator can resolve quite easily.
Check your Voicemail
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Best of luck!!
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
how to set up a greetings message
