Anonymous Posted on Sep 02, 2009
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo. For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD For Ricoh: VT/JP-6/JP-12/JP-500/JP-10 For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18 For Duplo: 504/51F4/544/744/ND 24 With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand. AEBO packing ,neutral and your customized packagings are all available. Sincerely hope a pleasant cooperation with you . [email protected]
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Sep 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
24288
Points
64
How could your ink work in a Riso RZ220?
How do i change the color of riso drUm from red to burgundy?
All you really have to do is put in the ink color you want and run a bunch of prints. Going from a light to dark color like black is fast--like about 3000 prints. Black to light color is going to be a lot more prints. Best is to print something with heavy ink. the more ink you put out the fast it will change color.
Hi is it? the ink for gestetner Duplicator to be able riso Duplicator. Is the material same materials? thanks yoel
Be aware that not all people would agree with my explanations ...
All inks for duplicators are nearly the same and therefore they are mostly interchangeable. Have a look at the DPI the ink is made for. Lower resolution ink may have bigger pigments and these may become stuck in the mesh of drum or the master. At least you have to fill the ink in an original bottle to use it. Avoid air bubbles!
Please weigh the risks before you continue. Techical difficulties may apply. So only courageous people should use foreign ink. - I have done often and my risographs still work very well!
2helpful
5answers
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
8helpful
6answers
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
1helpful
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
[email protected]
3helpful
Got error code e104 duplo DP-460H
[email protected]
2answers
RISOGRAPH RN2030 THERMAL HEAD PROBLEM
I think that you should check the connectors and ground wire, and clean surface of TPH. I have not seen one of these fail completly.
2answers
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Top Riso Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
