Recovery Toolbox for Word is repair tool for extracted text from corrupted Microsoft Word documents (*.doc, *.docx, *.dot, *dotx files) and Rich Text Files (*.rtf). Microsoft Word repair tool can fix errors in text documents: https://word.recoverytoolbox.com/repair-word/
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
You can often find the digital channel numbers for your local stations in a guide like http://www.titantv.com/ or https://tvschedule.zap2it.com/?aid=gapzap . Alternately, check if the local stations websites offer a link to their schedule. This will usually list the channel/channel digital identity. Another source for the digital channel numbers are the antenna choice/position/direction guides. Look at http://www.antennaweb.org or http://www.tvfool.com . Tvfool.com gives the direction and signal strength for all channel transmitters in your general area. Antennaweb.org is much more conservative and will only give the strongest stations in your area. That conservative list assumes an external antenna and clear path between the transmitter and your antenna.
In my area, the analog channel 7 became digital channel 7-1 . However, the channels 12 and 16 now transmit at 43-1 and 46-1 . However, after letting the TV do the auto-search, they are 12-1 and 16-1 when I type in the channel numbers on my remote.
I hope this helps. I might be able to provide a list of your local digital channels if you add a comment with your general location.
This error is caused by the wii not being able to connect to its access point.
To solve this error :
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using WPA encryption, the Wii is compatible with :
WPA - PSK(TKIP)
WPA - PSK(AES)
WPA2 - PSK(AES)
If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings. PCHELPSTER007 from YouTube, if I helped you please give me a nice quote or rate me, thank you
Wii Error code 52032 means your Wii's internet connection may be affected by a wireless interference. Make sure your wireless modem is close enough to your Wii, and not blocked off from wall, ceiling, or a floor. This can cause high interference. If this does not resolve your issue, try changing your wireless router's channel to 1, or 11. These channels do not overlap with other channels, so have the best luck.
Feel free to contact me if you have any further questions or problems!
Home wireless networks based on the 802.11b or 802.11g standards transmit their signal in a narrow radio frequency range of 2.4 GHz. Various other electronic devices in a home, such as cordless phones, garage door openers, baby monitors, and microwave ovens, may use this same frequency range. Any such device can interfere with a Wi-FI home network, slowing down its performance and potentially breaking network connections.
The 2.4 GHz Wi-Fi signal range is divided into a number of smaller bands or "channels," similar to television channels.Many wireless products ship with a default Wi-Fi channel of 6. If encountering interference from other devices within the home, consider changing the channel up or down to avoid it. Some Wi-Fi channel numbers overlap with each other. Channel 1 uses the lowest frequency band and each subsequent channel increases the frequency slightly. Therefore, the further apart two channel numbers are, the less the degree of overlap and likelihood of interference.
If this won't work, Then consider buying a new wireless router as your current is deemed broken.
Try changing your wireless channel.
first i would download and install this program
http://www.xirrus.com/library/wifitools.php
that will tell you all the networks being broadcast and what channel they are on
ideally you want to be on channel 1 or 6 or 11 - as they do not overlap
you should be able to download a manual from here
http://www.buffalo-technology.com/support/downloads/
you need to login to the router and then goto the wireless section and changed the channel there
looking at this model
http://www.buffalo-technology.com/products/wireless/wireless-g-125-high-speed/
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
