Looking for service manual/parts list for yaesu ft-ft41r or ft11r
need the key pad for the radio
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
SOURCE: Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
SOURCE: I need to replace the internal lithium battery on
I have a Yaesu FT-415 and the same problem. My original battery is a SONY 1220-VJ2H (solder tabs, blue insulation on the outer edge and two stick-on paper insulaters) and is soldered in to the Control PC board (mounted vertically). I'm going to get a new battery and hopefully am brave enough to get the soldering iron to the board. It looks like you have to unsolder the board from the speaker to lift it up enough to get at the solder tabs on the battery, luckily I have access to a Pace soldering station with a vacuum pump. I'll hopefully try this next week and get back to you all.
SOURCE: i need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
do you know where i can get the key pad,for the ft-11r? the one i have is missing one of the buttons,and another one is about to fall off too.
