My pool has stopped heating as much as normal. At first, the pool man discovered the sensor wasn't working. He fixed it and the pool began heating up quickly. Now, it has stopped heating again but the pool man said there is no problem. I have had the solar panels for 3 years and my pool is usually at 88-90. It's barely hitting 82 even when the weather has been 95-100. I can feel that the water coming in isn't very warm but I'm still being told there is no problem. Is there a way to diagnose if the thermostat setting or sensor is working properly?
If you pump is dual speed,try turning to lower speed and water will stay in solar system longer,thus having a higher heat gain
If the solar panels are hooked up the wrong way they won't heat the water as efficiently. Try reversing them. If I remember correctly one end is labeled with an orange sticker and that end is hooked to the skimmer and the other is hooked up to the pump...
