LG Shine CU720 Cellular Phone Logo
Posted on Sep 02, 2009
Want to block caller - LG Shine CU720 Cellular Phone
Anonymous
Level 1:
  • Contributor 252 Answers
  • Posted on Sep 02, 2009
Anonymous
Contributor
Level 1:
Answers
252
Questions
Helped
90979
Points
34
You can call your carrier and they can block specific numbers from going into your phone. I had to do this with my son's phone because the number was used previously by someone who had a lot of debtors calling and they were harrassing my son.
Just do a 411 from your phone and give them the phone number to block.
2answers
How can I block a caller
By using truecaller you can block a caller or go to phone setting to block calls, open the Phone app, select Call History, tap the number, then select Block Contact or Block Caller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.
Aug 08, 2018 • Cell Phones
tip
How do I Block a Caller on my Android Phone
<p>Here we discuss how an Android phone callers to block. These steps can be useful where you want unwanted calls directly instead of manually reject the call blocking. Follow these simple steps to block a caller making a call to the phone. Please note that the various steps may be other manufacturers like Samsung and Sony Ericsson and HTC. But the base should be almost identical. <br /> <p><br /> <p>Option 1 Steps <br /> <p>1. On the All Apps menu, click Blocked callers<br /> <p><br /> <p><span> </span>2. Click Add caller.<br /> <p><br /> <p><span> </span>3. Select from people (which are your on phone book) or just add the caller (if you remember the number).<br /> <p><br /> <p><span> </span>4. If you like people, click Save to finish.<br /> <p><br /> <p>5. If you add the caller number, click ok to finish.<br /> <p><br /> <p>Option 2 Steps <br /> <p><span> </span>1. All applications menu, click Find People. <br /> <p><br /> <p><span> </span>2. Select the caller wishes to block. <br /> <p><br /> <p><span> </span>3. Calling on the Block, "switching to. <br /> <p><br /> <p><span> </span>4. Click OK to close the. <br /> <p><br /> <p>This "Blocked Caller" function can be disabled, as shown <br /> <p><span> </span>1. All applications menu, click people blocked. <br /> <p><br /> <p><span> </span>2. Select the caller that you want to release. <br /> <p><br /> <p><span> </span>3. About Block caller, change On Off. <br /> <p><br /> <p><span> </span>4. Click OK to close. <br />
on Aug 18, 2011 • Google Android
Caller id log reads "empty" even when a call &/or message is left.
Check with the caller to see if they have "blocked" delivery of their caller id information. If the caller has blocked it, the phone cannot see it: some phones log this as "CID info missing" or similar verbage, others simply ignore the event. Good luck!
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Block Caller
Only if you have that future, if not call your local provider and ask for call blocking.
Blocking a caller
you should be able to block callers in your settings menu or in your phone book
2helpful
2answers
How could i block my Cell Phone Number From Caller ID
  1. Just dial *67 before the phone number on your cell phone. This code is the universal command to deactivate caller ID.
    For example, placing a blocked call would look like*67 555 555 5555 (without the spaces). On the receiving end, caller ID will usually display "private number" because it has been blocked.
    Though you won't hear or see a confirmation of a successful caller ID block, it will work.
1helpful
When someone calls me,it displays 'call' on Nokia E71,what to do? I don't have duplicates on my phone and when i type in *#30#,it says 'number of caller is not available'.Please help me
In some instances the caller might have caller-id blocked or a *67 manaul caller id block.
You are correct if you have a duplicate contact entry it does not show the name of the caller incoming.
1helpful
Can I block any particular incoming no.
With this model of phone you cannot block calls from a particular number but you can restrict incoming calls that are not listed your address book. So effectively you can block a caller but you will be blocking all callers that are not in your address book. Having said that, there are other phone models in the market that can block a particular caller by listing the number in a black list.
1helpful
Block calls from unidentified callers
this would be done if you put a request to your service provider.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
