I just installed a bicycle computer. The magnet on the spoke is about 12mm from the receiver as it passes, thus the computer is not registering speed. How should I mount the receiver so that it is closer to the magnet as it passes? Thanks.
On both the sensor stick (which goes on the fork) and the magnet (which goes on the spokes) there is a center line engraved on each. The centerlines on both have to cross each other at a distance of about 1/4" to register on the odometer.
You can use almost any magnet with a speed sensor because they all 'register' a loop of the wheel with a magnet field sensor. The magnet must be no more than 8mm from the sensor to register the field. IF it is an older magnet, you might need to get it closer to the sensor. I always touch them, then move one or the other away just enough so they don't bump. Works every time. :)
