I purchased a Sony Home Theatre system - model DAVHDX285. Sound is great - but the sound keep cutting out - system puts itself on MUTE for no apparent reason. Is there a remedy?
I have returned unit to store and now second unit (brand new) is doing same thing.
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-DAV-HDX285-Home-Theater-Systems-manual/id/23316bh343/t/2/
The TV and process the sound differently so the echo is a just a time smear. You shouldn't actually need to augment the HTS speakers with (ugh) TV speakers.
As far as comparative TV-sound loudness goes, if you drew it from the Cable Box to the audio system I'm sure it would be the same as your other audio. TV
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
