I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
I've attached an image to help out.
If the status light is blinking red:
1 time- lamp cover or housing error. check lamp door.
2 times- temperature error.
4 times- fan error. one or more fans bad.
6 times- lamp fails to light. if lamp is new, ballast is bad.
The power and status light blink together i cant operate my projector
Slide panel out half an inch. Using thumb and index finger squeeze end of cover and pull out
