Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
If your Viore TV is unable to scan digital channels after a power outage, there are a few things you can try to fix the issue:
Check the TV's antenna connection: Make sure that the antenna is securely connected to the TV and that there is no damage to the cable.
Rescan for channels: Go to the TV's menu and select "Auto Tuning" or "Channel Scan" to rescan for channels. Make sure to select the option for digital channels only.
Check for software updates: Make sure that your TV has the latest software updates. Go to the TV's menu and check for any available updates.
Perform a factory reset: A factory reset will restore your TV to its original settings. This can sometimes fix issues with channel scanning. Consult the manufacturer's manual for instruction.
Check your TV's location: Make sure that your TV is in a location where it can receive a good signal. Try moving the TV or the antenna to a different location.
If none of these steps work, it's possible that the TV's tuner may be malfunctioning and may need to be repaired or replaced. Contact the manufacturer's customer service or a professional technician for further assistance.
How to put av on tedelex 72 cm TV model 9628MK11 72 manually
To manually switch the input source on a Tedelex 72 cm TV model 9628MK11 72 to AV, you can follow these steps:
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Universal remotes don't do all the functions that a manufacturer remote do not http://www.tvremotes.com.au for remotes in Australia
If you use a set top box tuner the TV will become the monitor and the box will become the tuner and use one of the rear or side video inputs and bypass the internal tuner and just programme the stb remote to set the TV volume to the desired level
The above link may have the remote you want but as I am in the UK the server blocks me
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box. If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time. Switch to the TV tuner, you see cable. Switch to the recorder (connected to the CableBox) and you see what you can record.
With all receivers, depending upon the type cable going from the receiver to the TV, the TV is set either to a channel or an input setting (if using any cable other than a coax cable). I hope this helps.
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
click menu, on station prog go to EDIT. Press blue button twice, then go to rescan prog. (it seems to clear all previous scanned programs and starts again.
