Master
- Posted on Aug 31, 2009
Re: Fes330 roper stove power to stove ...ok no fault...
You have no heat at all? K, pull stove out and check how many volts you have should be 240. Your elements work off 240 if you only have 120 coming to stove the lights will work jujst not your heat. You should have a double pole 40amp breaker If you only have 120 change the breaker
