GPS Logo
Posted on Aug 31, 2009
No satellite coverage anywhere. seems to have just stopped working. have reset twice with no luck.
My garmin nuvi 660 stopped receiving satellite signal. Reset has no effect. Everything else seem to work.
Power your unit on outside, make sure you have a clear view of the sky. If your unit is working properly, then it should pick up the satellites. If so, then you can put the unit back in your vehicle and make sure it is positioned to maintain a satellite lock. If you cannot acquire satellites outside, then the unit is defective.
Jan 01, 2017 • Garmin GPS
2answers
What are the main advantages of using a satellite phone?
the most obvious advantage is that they will get service in remote places on earth where normal terrestrial servers don't cover
Jan 28, 2013 • Cell Phones
3helpful
2answers
What does it mean error 5b00, and how do i resolve it
You will have to do a reset. Follow the instructions below
1. power off.
2. hold stop/reset, hold ON/OFF
3. release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4. wait untill LCD display shows “Canon Idle”,then push stop/reset four times, quickly
5. then push power twice, quickly
6. power off and power on
My canon Pixma IP1500 start blinking 10 times alternationg orange and green, then repeats. I even reset waste ink counter, but no luck. Please help me out. Thanks.
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Blue tooth problem
dead zones there is no 100% coverage ---onstar is like a rolling cell phone there are dead zones to deal with
TomTom One 3rd edition was working fine for hundreds of miles, then it just started tell me to make strange directions in the middle of an interstate. It then lost satellites. Would come back and give...
The problem may be caused by a lose of satellite coverage. This is a bug that is caused when the GPS can not access satellite for a long period of time. To avoid this you will need to keep the GPS up-to-date by connecting to your computer and download updates using TomTom Home
8helpful
2answers
I can't turn off the red keys on my Toshiba Satellite L300.
you press ctrl+shift either once or twice, it will revert back to the normal keys.
Toshiba A205-S5819 Can't connect to wireless internet
The router you're trying to acess may not be set up for Vista or may not be compatible with Vista. I had to upgrade the router at my shop in order to work on Vista OS machines.
2answers
Did you ever get your starmate to work?
same here...
happened today...these all seem to have expiration dates
it came to life twice but now , it's possible fubar
shame to throw away,as i have the home kit .. non compatible , or buy another?
70helpful
9answers
Canon MP150
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
