The power of the phone turns off frequently. This is happening even when i ensure my phone is locked when it is idling. I usually carry the phone in the pouch hooked to my waist belt.
here's the deal.. go for hard reset or hard reformat. it should delete all files.. all in all , locks and freezes are not phone malfunction, it happens to me and i think your phone carrying a virus or a worm!
sounds like the safety thermostat (Hi Limit Thermostat) is cutting your dryer off. This usually happens because of hi heat (higher than normal) which is caused by clogged exaust.
Check your dryer vent to ensure that is is completly free of lint. Clean the lint from the lint trap all the way to the output of the exaust outside your dwelling, ensuring the dryer has a unobstructed flow of hot air.
best thing to do on the short-term is to powercycle, just turn it off, take battery off, wait 15 minutes and put it back on. It is usually recommended to do this about once a week with most phones, but if this happens even if you turn your phone off frequently. You should contact your service provider, if you are out of warranty with them, make sure you look into your manufacturer's warranty since battery warranties usually always have an extended warranty by the manufacturer not the service provider, in this case motorola, so you would also have to check with them in regard to getting it replaced or fixed.
You have not specified under what scenario you are facing this problem
Pls check if you face this problem while not using the phone if it's idle, or do you face this problem while powering the phone on, or does it go off by itself while charging the phone.
however one common problem could be as follows:
If your phone turns itself off when being transported, something in
your pocket or bag has probably activated the on/off button. To avoid
this you can turn on the automatic key lock function.
Please note that if
you click the on/off button for more than 10 seconds the phone will
turn off, even if the key lock feature is activated. This is to ensure
that the reset function is always available.
I have found you need to be very accurate with the placement of the of the paper guide box and ensure it is completely locked in to ensure the printer will turn on. This is the manual feed box at rear of the printer. Cheers Yoga2
