The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again. To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Sprint Epic phones work off of a micro sd card, the slot to insert a micro sd is on the back right next to the battery. You cannot use a regular sized sd chip with the Sprint Epic.
The memory card might not have clicked into the slot , so remove and check the direction youhave inserted the micro sd card. Remove and push it to CLICK on to the latch , Now it mut be detected to open the files present.
These are the physical specs of Kodak Easyshare V530
The bottom and the top of Kodak V530
The left side and the and the front of Kodak V530
The back -lcd display and the right side of Kodak V530
On the right side of the Kodak v530, just look at the above image, you will see a slot in the center of the silver band covered with white felt curtain that protects it from dust. On this slot is where the SD card is inserted. Just insert the card carefully, and feel the click when SD card is placed properly, and push the card carefully until it bounced back and release from the slot when removing the SD card.
Hi, I think you are telling about the adapter if you are trying to insert a micro sd card then insert the card in the adapter and then try to insert it in the slot if you are using a big sd card then directly insert it in the slot.
the sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
Peel back the rubber gasket to expose the SD card slot. Do not completely remove the rubber gasket. Push the SD card until you hear a click. Do not attempt to pull the card out of the slot Remove the SD card from the slot. To Insert new SD Card Insert the SD card into the slot (Do not force the card into the slot.) with the metal contacts going in first and the beveled edge to the left. Push the SD card until you hear a click. Close the rubber gasket.
To insert the SD Card you had to push it in the SD Card slot until it stayed in the phone. To remove the SD Card simply push the SD Card into the phone and it will eject itself. I think it is spring loaded or something. It's almost impossible to remove the SD Card by pulling on it.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first:
* Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations.
* Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot.
* The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot.
* Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot.
* Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced.
* Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
