SOURCE: Dyson DC07, too much suction...?
have you checked that the roller is turning when the vacum is not in the upright position as ther are 2 belts 1 from the motor to the clutch and 1 from the clutch to the roller if the clutch belt breaks you will find it hard to push because the roller is stopprd.... lie the machine down on its side with the vacume in the open position not upright and check if the roller turns it should only stop when in the upright position. PLEASE MIND YOUR FINGERS.
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
SOURCE: Dyson DC07 - broken 'Contact Head' release clip
Hi Wombat64
We noticed you are having difficulties with your Dyson vacuum cleaner. We think we can help, simply call our Customer service team for free on 0800 298 0298 between 7am - 10pm, 7 days a week.
We look forward to hearing from you.
Darran
Dyson Customer Service
SOURCE: DYSON MOTOR BRUSHES
how do I change the carbon brushes in a dc07, I have removed the brush units from the motor
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
