1996 Plymouth Grand Voyager Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need diagram to locate starter for 1996 grand voyager 3.3 l
Would also appreciate diagram to show location of both oxygen sensors...can't get good idea from Haynes manual
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on Aug 31, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
599433
Points
5720
Starter is located where the engine and transmission meet
Where are the oxygen sensors located on 2003 Kia Rio 4 door sedan?
no need for a diagram
the heated oxygen sensors are in the exhaust manifold/ pipe before the cat converters
one in each bank
Diagrams of oxigen sensor
your oxygen sensors locations.one oxygen sensor located in the exhaust pipe before catalytic converter.the other oxygen sensor located in the exhaust pipe after the catalytic converter.
1helpful
Where is the pcm located on the plymouth voyager 1996
Hi there:
On 1996 Plymouth Truck Voyager 2WD 3.3L MFI 6cyl the ECM (Engine Control Computer) is located under hood, driver side, front side of strut tower, mounted on inner fenderwell.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
What does code #167 for a plymouth grand voyager mean?
P0167-/ 02 (oxygen) Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
2000 grand voyager starter location
Hello! Here is a diagram of the starter location for your vehicle...Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
6helpful
1996 Plymouth grand voyager se-need diagram showing where body control module would be located.
The BCM is located on the drivers side under the the steering column. It is behind the fuses and to get to it you have to remove the bash board plastic, than a pice of metal and than you have to remove the fuses box. It will take you approximately 20 min to remove everything. Once you remove the BCM you need to take note of the Part Number P/N. It has to be the same P/N on the replacement BCM. You can use any BCM from years 1996-2000 but make sure the electrical configuration is the same as yours (Power windows, alarms, etc.). I bought my BCM on the junk yard for 35 dollars and my car works perfectly.
I hope this may have assisted you,
Tom
2helpful
Where is the speed sensor location on a 1999 plymouth grand
<img src' "http://www.2carpros.com/forum/automotive_pictures/170934_plymouth_voyager_1.jpg" />
This is a diagram of where and what it looks like. Its located on the back side near the firewall on your transmission. GOOD LUCK!
2helpful
Need a diagram of under the hood 1996 Plymouth Voyager
Go to the autozone website at autozone.com and register your vehicle. It's free and you will have access to a full online repair manual for your vehicle. Hope this helped and best wishes.
4helpful
O2 Sensor on a 1996 Cadillac Eldorado
Hello mrsalbert, my name is JShreader. Thank you for choosing fixya.com
Depending on which oxygen sensor you are looking for...there are several of them throughout the Exhaust System. I will start out by giving you a brief description of what and oxygen sensor is, and they're general purpose.
DESCRIPTION
Four Heated Oxygen Sensors (HO2S) are mounted in the exhaust system where they monitor the oxygen content in the exhaust stream. There is an oxygen sensor mounted in each exhaust manifold and one on each end of the catalytic converter. the oxygen sensor located in the front exhaust manifold is the Bank 2 Sensor 1 (Front) sensor. The oxygen sensor located in the rear exhaust manifold is the Bank 1 Sensor 1 (Rear) sensor. The oxygen sensor located in the Y-pipe ahead of the catalytic converter is the Bank 1 Sensor 2 (Pre-converter) sensor. The oxygen sensor located in the catalytic converter outlet is the Bank 1 Sensor 3 (Post-converter) sensor.
OPERATION
An oxygen sensor acts like a battery because it creates its own signal voltage once it reaches operating temperature. This voltage is produced when the oxygen content in the exhaust stream is different than the oxygen content in the atmosphere. A lean condition (high oxygen content in exhaust) will produce a low voltage (near 0 volts) and a rich condition (low oxygen content in exhaust) will produce a high voltage (near one volt). The PCM provides a reference signal voltage (0.45 volt) and a ground to the sensor. The PCM reference voltage is necessary because the oxygen sensors do not provide their own voltage until they reach operating temperature.
HEATING ELEMENT
the oxygen sensors also incorporate a heating element inside of the sensor housing. This heating element is energized with the ignition On and allows the sensors to reach operating temperatures quickly. The PCM can then use oxygen sensor information sooner after engine start-up.
PCM INPUTS
The PCM uses oxygen sensor information during Closed Loop operation to constantly adjust fuel control to reduce exhaust emissions. Because the oxygen sensors provide information sooner after engine start-up, exhaust emissions are reduced. Faulty oxygen sensors will cause various driveability conditions and will set a DTC.
That being said...I uploaded a .pdf for you of pictures showing the locations of ALL the oxygen Sensors on your Vehicle. You can download it by clicking HERE.
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Two codes...need the actual physical location of oxygen sensors
pop the hood and look behind the engine in the middle....you'll see o2 sensor on the top of the exhaust pipe unplug it and remove it ............second o2 sensor is located on the same pipe under the passanger seat under the car
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
