F 9 MESSAGE MICROWAVE SHUTS OFF RUNS ABOUT 15 SEC
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If
yours won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full
You can just enter your full
parts site.
On the resulting page, look to the right for the blue "View manuals"
button. Click there.
That Sears-related site has many free manuals. While the manuals they
list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions
inside.
If yours is not listed there for free, you would have to order it
through the Sears
parts site.
We're
SOURCE: kenmore microwave model 721-63252301 - no heat
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
