I am being charged 4.99 a month for a tb system mechanic that I have know way to use or to get rid of. Please help.
Every time I see the words System Mechanic now I run.
Download Revo Uninstaller from www.download.com this is a free download and a freeware program. Once you install it, run it and it will list all programs loaded in your machine. Choose system mechanic from the list and click on option (4) say yes to all questions concerning uninstalling and wait for program to get rid of it. When it finishes each scan, click next and answer yes to get rid of files and then click next when it is finished. This program will not only get rid of the program but all its registry files as well. Then download a program called Malwarebytes Malware from www.filehippo.com and install and run that and perform a quick scan. when the scan is complete it will show its results, click on remove and it will get rid of any malware that is masquerading as a legit program.
Switch On
your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
If you feel that, my answers have helped you getting
solution to your problems then please give a vote.
Thanks.
Note: Please click on ' Accept' to accept my answer because it is your Acceptance, which gives us motivation to assist you with more efficiency.
