I have a new Sony Bravia television and the hdmi ports stopped working. I tried multiple cables and and can use my hdmi devices at other peoples hdtvs. Is there a way to fix this or must sony replace the board?
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
I have a Sony KDL-46V5100 TV and suddenly couldn't get my PS3 HDMI input on any port. Unplugging the TV and turning it on by holding the power button for 10 secs worked. Prior I tried everything I could find thinking it was the PS3 that was broken initially (unplugging the PS3, holding down the power on the PS3 for 6 secs to hear a total of 2 beeps while turning it on to reset the video settings, updating the PS3 firmware, bought new HDMI cables, tried incorporating an HDMI switch in the mix [ref:http://www.thebuzzmedia.com/ps3-hdmi-bla...]). I was about to try updating the TV's firmware when I stumbled on the solution. It's all working now and I was afraid to update the firmware since it's a non-reversible option though that might be the solution on your set up.
i had update firware and change hdmi cable that working on another television.. but stil no signal
