HP Pavilion G60-235DX notebook Logo
John Tonkinson Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop use away from home
Can I access my home network to get on the internet away from home if I have a Linksys WRT54G2 V1.3 router?
I use Network Magic. Does my router network only work in my home?
Should I use a nonsecure network away from home If I can't pick up my own
network?
Any help would be greatly appreciated.
Thank You, Davido
  • John Tonkinson Aug 30, 2009
    Thank you AWBroadwell
Anonymous
Level 2:
  • Expert 150 Answers
  • Posted on Aug 30, 2009
Anonymous
Expert
Level 2:
Answers
150
Questions
Helped
35892
Points
454
You cannot access your home network while away from home with your current hardware setup.
It is perfectly fine to use a nonsecure access point when away from home but just make sure you turn off any sharing you have of your devices so nobody can browse your computer.
1helpful
I am trying to connect my work laptop to my wireless network at home, it says my router isnt secure and wants a CryptoAPIPrivate Key
Can you access the network using cable? Check the security setting of your router. Check the WPA-PSK key and use it as the password to access the network
2answers
Linksys wrt54g2 router not allowing connection wirelessly
U can try reset the router back to default factory mode, then reconfigure again...
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
2answers
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
1helpful
2answers
Linksys Wireless-G 2.4Ghz Broadband Router Problem
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
