Question about Onkyo Audio Players & Recorders
Dear fixya team What's the net weight of Onkyo passive subwoofer including woofer?
6ya staff
SOURCE:
Michael Borelli
  • 979 Answers
SOURCE: Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Posted on Feb 29, 2008
Anonymous
  • 185 Answers
SOURCE: Trying to find out which
an 8 gauge should work thats a small amp and remember that the same gauge that u put on as a power wire make sure the ground is the same gauge
Posted on Apr 05, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Posted on Jun 21, 2009
Anonymous
SOURCE: onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Posted on Feb 12, 2010
trachysa
SOURCE: I have an AR s112ps subwoofer. I woofer is blown
all you need is an 8 ohm subwoofer or a Dual Voice Coil (DVC) 4 ohm subwoofer wired in series that can handle 120 Watts rms. I Went with a Rockford Fosgate Punch P1 P1S812 12-Inch 150-Watt Subwoofer - 8 Ohm
it was only $35 from amazon and is probably nicer quality than the original driver. Good Luck
Posted on Jan 16, 2011
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
How many watts is these woofers?
Manufacturer Alpine Wattage 600 Watt Speakers Format Round Active / Passive Speakers Passive Speakers Installation Built-In Category Pair of Speakers, Subwoofer Number of Ways 2, 1 Size (Diameter) in mm 250 EAN 4958043515356
Sep 30, 2010 | Alpine SWS-1040 Car Subwoofer
I have no output from subwoofer
Hello Fixya customer,
Thank you for your question.
Please check that the sub woofer and RCA cable are working by removing the RCA wire from the Sub woofer output of the Onkyou and touching the center terminal of the RCA plug. You should here a hum when it is touched.
If you get the hum, then the next step is to "Clear" the Onkyo by holding down the "VCR and Stby" button until you see "Clear" on the display. Warning, this will clear any settings special that you have made to the receiver, but will get you back to the Factory settings.
Lastly, check various sound fields, and the Sub woofer volume setting, if you still do not get sound, please have a Onlyo service center verify the output.
Thank you using Fixya.
Apr 28, 2010 | Onkyo TX-SR606 Receiver
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
Passive radiator speaker wiring
Passive Radiators are not driven by the amp. They have no voice coil and no power goes to them. They are used to enhance the bass or lower frequencies in a speaker system. They work by utilizing the back pressure that a driver (woofer) produces. When a woofer produces sound, it moves forward and backwards inside the speaker cabinet. This backward motion is what drives the passive radiator. So in order for the passive radiator to work, it would have to be placed in speaker cabinet along with a woofer that is hooked up to an audio amp.
Jul 23, 2009 | Audio Players & Recorders
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Feb 26, 2008 | Audio Players & Recorders
Connecting a passive subwoofer!
I believe the sub output that uses a RCA plug is not amplified and wouldn't work in your case.
Nov 14, 2017 | Onkyo TX-SR502 Receiver
27 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
