Question about TruTech PM1919BXA1 19 in. LCD TV
What is the difference between HRC, IRC, Std and Auto when scanning channels - I hate the new digital TV world - it has total confused things - I have comcast cable
  • 93 Answers
Usually standard broadcast is is the default setting,some other cable company use HRC and URC, these are ways to transmit or deliver their signal trough cable wire,ask comcast cable for their transmission type.
Posted on Aug 30, 2009
6ya staff
SOURCE:
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
How to get cable channels over 119 - not available
contact your cable service provider.as he will checkout the frequency of the cables in both the rooms.
Oct 05, 2008 | Insignia 19 in. Widescreen Flat-Panel LCD...
I had comcast before but now i don't ,don't use a converter box and somehow I was getting cinemax and other channes on the tv,now i am not I auto programmmed the tv again and mess the the channels...
> I had comcast before but now i don't, don't use a converter box and somehow I was getting cinemax and other channels on the tv
Comcast was providing Cinemax and many other channels as part of your paid services and you will not receive these unless you are a subscriber. There is a good selection of free broadcast channels unless you live outside city areas. If you do, you will then need an external antenna and probably an amplifier to get more distant signals. Auto programming will not find the channels you were receiving from Comcast so there will be only accidental channel duplication; for example, if your former channel 10 was NBC, it may be channel 7 when receiving signal from an antenna.
There are essentially no more 'Analog' stations still broadcasting, they are now all 'Digital.' The abbreviations 'Std' refers to the aspect ratio (H/W) of the picture area and 'Hrc' and 'Irc' the available resolution or how many pixels and lines on the screen.
Aug 28, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Cannot connect to cable
if going to straight cable 1)make sure not in an all digital market. you may need some type of box. 2) if can hook straight make sure if it it has an option of HRC or IRC and make sure it is HRC or (std) in some cases.
Aug 18, 2010 | JVC AV-32120 32" TV
Samsung 40'' LN40C530F1F Setup Help Needed
I would suggest calling your cable service provider. I just purchased the same TV and experienced the same problem/question. I have ATT Uverse and called and spoke with technical support. They said that you need a HDMI cable and the cable settings need to be set to HRC (High Resolution Compatible) or someting like that. The other 2 settings are analog modes! I had mine originally set to STD I just randomly picked this setting and had my TV conected to the cable box useing a coax cable, this is why it looked strange. I hope this helps? I will be picking up a HDMI cable on my way home from work today and will change my cable setting on my Samsung to HRC. If this does not fix the problem I will repost tomorrow, but I am sure this is the solution. Happy viewing!
Apr 08, 2010 | Televison & Video
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Channel search: skips chanels
If you have a cable box connected, it's synch circuits are bad. If your TV has a selection for HRC/ IRC make sure you know which one cable company is using .
Apr 15, 2017 | Polaroid FLM-1911 19 in. LCD Television
Screen remains blue with "no signal" written on it, inspite of a cable connection and, of course, the input set to cable
Probably a bad video processor board
But, 1st try using a different type of Cable such as IRC, STD, or HRC different freqs and channels
Also, try using a vcr or dvd on one of the inputs to see if that works
Jonathan
Oct 26, 2008 | Polaroid FLM-3732 Television
TruTech PM1919BXA1 19 in. LCD TV Logo
8,412 people viewed this question
Top TruTech Televison & Video Experts
Eric Rotmil
Eric Rotmil
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
