RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blackberry Curve 8320 Won't Charge
I have similar problem. Phone won't charge from mains charger or from computer. Says charging but acually does nothing. Even tried doing an update, and new battery but problem remains.
I have to charge it by removing battery and attaching the red(+) and black(-) wires from old 4.5v 500ma charger to the + and - tabs on battery with a multi-meter between them. I usually give it 15-20 mins and keep constantly checking it.
PLEASE DO NOT TRY THIS. Li-ION BATTERIES CAN EXPLODE IF CHARGED INCORRECTLY, OVER-CHARGED OR DAMAGED.
  • cyberraxx Aug 30, 2009
    I can still access the phone via USB on PC, it just won't charge but it looks like I'm going have to do as you suggested. Tried every other idea I can think of.
    Thank you Azum for your quick response.
Anonymous
Level 3:
  • Master 400 Answers
  • Posted on Aug 30, 2009
Anonymous
Master
Level 3:
Answers
400
Questions
0
Helped
113571
Points
1295
Sir,
Your cellphone Charging jacket has to be changed or repaired trough near by mobile shop.
Blackberry won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
My blackberry curve won't charge
First, make sure the charger is working. If charger is working, then it means the charging port is defective and needs to be replaced or serviced.
Regards.
Jan 16, 2012 • Cell Phones
Why will my blackberry curve will not charge?
I advice you try charge with a similar charger to see if it will charge, it did not charge, then it means the charging port on your blackberry is bad and will need to be replace but if it charges, it is the charger you will need to replace.
Check with a similar charger to see if it will charge, if not, go to any phone service center within you vicinity to help you replace the charging port and you will see that after replacing the charging port, your phone will charge.
Take care
Jul 05, 2010 • Cell Phones
2helpful
I cannot charge the blackberry 8320 and the battery is new.It was charging just fine. I change the battery and the charger.and it still has the problem.
Hi, my name is jeff and I work for a used cell phone and repair store in Sioux Falls South Dakota called THE CELL PHONE GUY. what could be going on is that your charge port is broken or loose. there are about 4-8 prongs that are solderd on to your board, those will come lose or break from dropping the phone, hagining your phone on your charger, or just normal wear and tear of putting your charger in and taking it out. you would have to re solder a new charge port on there to fix that. luckily my company THE CELL PHONE GUY are highly trained in charge ports we have done over 2000 charge port repairs with 2 coming back on warranty, if you want us to fix it give us a call! 605 335 0411
2answers
I have a bb 8320 and when i plug it into the wall it charges but when i plug it into my laptop nothing happens why is that?
If your regular charger is working in the wall, it sounds like the USB cord that you are using with your computer isn't a "charging" USB. I don't think you are having a malfunction with your BB.
5helpful
4answers
My usb port is damaged on my blackberry can not charge it how do I charge the battery? I cant charge it via the usb port which is needed for almost everything. is there another way to charge my blackberry...
The only thing you can do is use another BB to charge up the battery, and then swap batteries. Someone usually has a broken BB (screen dark, sound stopped working etc) which they will give you for free..
8320 curve battery in not charging through any medium.
i have the same problem, the solution is to go to BlackBerry Service Centre or buy external charging device for battery.
Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
1helpful
2answers
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. The icon stays on with the backlight until the battery dies, A new battery was tried and problem...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
