Samsung HP-R5072 50 in. Plasma HDTV Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having small red dots show up in the middle of the screen. Some of time, when there is an outdoor sceen and the light is very bright you can't see the dots. H owever, when there is a scene where there is some darkness you can easily see the red dots. WHAT'S HAPPENING?
electroman
Level 3:
Genius:
  • Samsung Master 1,039 Answers
  • Posted on Sep 01, 2009
electroman
Samsung Master
Level 3:
Genius:
Answers
1039
Questions
Helped
304844
Points
2353
Panel is bad. Contact Samsung to see if they will replace the panel.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1187
Points
THE PC IS ONLY ONE DAY OLD SHOULD I JUST TAKE IT BACK..SMALL RED DOT IN MIDDLE OF SCREEN..IS IT TRUE THESE MACHINES ARE A ..."JUNK:;
Black dots in middle of screen on 50
Hi
Go into picture in the setup and try to make the picture as bright as you can. That could do the trick.
All the best
kolbrun
1helpful
Hitachi 50v500 sceen has little dots showing
You have a set that was involved in a large class action lawsuit---the optical engines in this model had issues where they turned red or another color---little dots in picture is a classic optical light engine problem---last time I looked the part alone not counting labor was over 600 dollars.
It has blue dots in the middle of the screen
This is a defective Light Engine Assembly. The average cost to replace it is around $650.00
1helpful
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Two blue dots on the screen
its sounds like the guns has burnt your yube, when switching of does your tv show a bright circle in the middel, or while watching. Smack your tv on the side while on see if the picture goes away or make a bright circle in the middel, this is caused by a bad solder joint but you wont get rid of the bunt pixels sorry.
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
1helpful
2answers
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
