Our lap started getting hot and then it shut down but now the lcd hard drive cd rom nothing else works. A friend told me to look at the solder joints on the motherboard to make sure they were not cracked,if anyone else can help please i need it,im mecanicaly inclined with high and low voltage electrical tech we love this note book and love to get it running agin. Thanks for any help
Better check first your air vents/holes for build up clogs. Might be a thermal problem. Blow that using compressed air can. Second check your memory card, might be dirty contact with the connector. Cleaning using a soft eraser only its edge connector. But disconnect first the battery and Power Adaptor supply line and power it down completely before doing so.
Could be its problem is dirt build up. If this first steps fails, consider your plan checking its internal. For overheat and other check up.
For inputs, hope it helps.
Testimonial: "i di clean it and man was it full of dust but after i put the computer back together it done it agin so i went to the ram and found a corrupt ram "
