SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
SOURCE: water under crystal
Obviously you have moisture inside the watch. If the crystal is not cracked then moisture can get in around the stem if the seal is no longer good. Although also possible is from a bad seal on the case back. These seals need to be replace every 3 to 4 years and then properly lubricated with a special silicon grease. With time, the seals will tend to flatten out and the grease will dry out. So get it serviced before the moisture will permanently damage it. Also. 330 ft is if you decend slowly. If you jump in a pool or subject it to a heavy spray, like in a shower, that is another story and they don't always keep the water out then.
SOURCE: moisture under lense
Moisture can sometimes be removed by putting your watch in a warm place and leaving there for a day or so.
If it persists, then it may be necessary to remove the back of the watch. This is usually best left to a jeweler, especially if it is a waterproof type, as the seals can be difficult to re-fit. If your watch is still under warranty, then you may invalidate the warranty if you try any self repairs.
