I came home one day 2 months ago, my ATT-1726 answerign machine had a blinking "CL". At first I thought it was just a power failure so I reset the clock. That done, I saw a big "0" which told me that ALL my 27 saved messages are gone permanently!
(NOTE: in order to erase msg, we have to press DELETE twice and I am 100% sure I did not press it even one).
Last week , the same thiing happens: CL was blinking, clock was reset, all saved msg were gone.
What happened?
Thank you.
You might try unplugging the AC power to the unit, let it sit for 5 minutes, and reconnect the power. That sometimes resets the unit to the factory default. You can then reprogram.
1) Call your telephone numer
2) During (or right after the announcement), dial your access code.
3) Press "5" during the session to use the various codes listed in the manual.
4) Press "*9" to end the call.
Press the mail box button quickly to hear only new messages. Press and hold until you hear the system respond to hear all messages. Press again to stop playback.
unplug NOW before someone tapes a messages over the "deleated"one try plugging back to power after machine has had 5min downtime this may 'reset' so you can retrieve if this does not work call manufactor they may know a trick but do not reconnect because if someone tapes over its gone!
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
I have ATT VOIP service. You are probably recording your messages on your ATT voicemail. Change the # of rings for the voice mail to pick to more than the answering machine picks up. You have to get into your account and look for the section that allows you to do that.
