KitchenAid KCMS145J Microwave Oven Logo
Posted on Dec 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is a GE microwave. A muffin got burnt and the burnt smell won't leave the microwave
A GE microwave. My husband burnt a muffin in the microwave. I cleaned out with baking soda and water and even tried vinger but the burnt smell won't go away when cooking.
  • Anonymous Mar 28, 2014
    there is two ligt underneath the Microwave 1 is burnt
  • Anonymous Mar 30, 2014
    I need to get rid of the smell that is coming from my microwave. I've tried to put lemom juice in there for 24 hours, buttha didn't work.
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on Dec 06, 2007
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4481707
Points
21747
Many solutions are found here:
http://www.google.com/search?num=100&hl=en&safe=off&q=microwave+smell+OR+odor
We're happy to help and we appreciate your thoughtful rating of our answer!
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: burnt smell in microwave from burnt muffin in a GE microwave
http://www.google.com/search?hl=en&q=microwave+smell+OR+odor&btnG=Google+Search
We're happy to help and we appreciate your thoughtful rating of our answer.
Rag burnt, is it safe to use the micro? The rag burnt badly, there was smoke and a strong bad smell persists. Is it safe to keep on using the micro, what can be done about the smell?
Hello -
It is probably safe to use the microwave oven after removing the burned smell.
I found some methods for removing a burned smell from a microwave.
https://blog.bostonappliance.net/5-foolproof-ways-to-get-burnt-popcorn-smell-out-of-the-microwave/
(Quote)
1. Fill a bowl with 1/2 cup water and 1 tablespoon white vinegar.
  • Microwave it for 4-5 minutes and leave it with the door shut for 10-15 minutes.
  • Steam will loosen smell-causing detritus stuck to the walls. Vinegar absorbs odors, even stubborn ones like burnt popcorn smell.
  • After the waiting period, remove the bowl and wipe the inside of the microwave down with a paper towel
2. Not good enough? Okay - soak a sponge with vinegar.Place some baking soda on top and microwave the sponge for 25 seconds.
  • Wipe the inside of the microwave with the sponge.
  • Don't forget the glass tray and the microwave door.
3. If steps 1-2 don't remove all the grime, soak cotton balls with acetone-free nail polish remover and wipe down the inside of the microwave.
  • Even stubborn stains should come out.
  • Wipe down the inside with soap, then vinegar water, to remove the polish remover.
  • We recommend following through with step 4 to get rid of chemical smells.
4. Banish the remaining smells with the power of citrus.
  • Peel two oranges or slice a lemon in half.
  • Place the orange peels or lemon slices in a bowl of water (1-2 cups).
  • Microwave it for 4 minutes. Watch closely to ensure that the water stays in the bowl and the citrus peels do not burn.
  • If possible, leave the bowl in the microwave (with the door closed) for 12 hours.
  • Too time-consuming, or just not doable for you? That's okay too. Let the bowl sit in the closed microwave for half an hour then, if the burnt smell persists, continue to step 5.
5. Still bad odors in your microwave? Leave an open box of baking soda on your microwave tray overnight.
  • It will neurtalize the odor without adding to the smelly situation in any way.
  • You can also place coffee grounds from your morning coffee in a bowl in the microwave all day while you are at work.
  • If you don't mind coffee smell, you can microwave 2 tablespoons of coffee grounds in a half cup of water for 2-3 minutes to expedite the process.
(End quote)
Best wishes.
GE jvm1631wb003 not heating has a funny machine smell
Most likely the magnatron has gone out and it runs around 90 bucks. If something is funny smelling then by all means don't use it unless you want a fire. If it were me I would replace the oven instead of throwing money nto a repair on a used microvave, they simply don't last as long as they used to. It won't hurt to take the cover off and inspect it for burnt wires that may have grounded out, if none found I would replace the unit.
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
I have a GE JE2160SF01 spacesaver microwave and clock works but the microwave does not turn on, this is the second time this problem occured the 1st time is smelled like wires were burning...looks like...
WHERE THERES SMOKE THERES FIRE LEAVE IT ALONG.
TO REPAIR THE MICROWAVE WILL COAST YOU MORE WHO EVER WORKS ON IT WILL HAVE TO REPLACE BURNT WIRES
AND POSIBLY A SWITCH...TAKE MY ADVICE BUY A NEW ONE
WITH WARRENTY AND YOU WON'T HAVE TO WORRY ABOUT SMOKE IN THE HOME.
Loud noise followed by a burnt smell coming from the control panel. Not heating up at all.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.'';
What is the best way to remove burnt smell from microwave. My dgthr burnt macaroni
Put vinegar in a glass and microwave it.
After it boils take it out and clean your microwave with a disposable towel. Hope this helps.
1helpful
Capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Burnt smell in microwave from burnt muffin in a GE microwave
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
