Question about Panasonic Lands Phones
Cannot register Panasonic Phone I purchased. Get it to say "Registering" and then goes to saying "Base no Power"
6ya staff
SOURCE:
Anonymous
SOURCE: Registering a new phone
I tried your solution - putting the phone on the answering machine charger and it worked! Thank you!
Posted on Dec 28, 2007
CORDLESSGURU
Chris Barclay
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
Anonymous
  • 3 Answers
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Posted on Feb 14, 2008
Anonymous
  • 5 Answers
SOURCE: How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Posted on Nov 07, 2008
bigbeatpro
SOURCE: unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Posted on Feb 19, 2009
"Base no power" when registering panasonic KX-TGA750 phone to KX-TGA642 Panasonic phone.
The base is the one with the small antenna and it has no power to it, either the base is defective or the wall plug adapter is no good.
Dec 05, 2016 | Panasonic Lands Phones
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Mar 24, 2017 | Panasonic KX-TG2356 Cordless Phone
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
I have a model KX-TG9332T.... I cannot get the handsets to link with the base...I have unplugged, moved the system, changed the batteries and both handsets continue to get the message cannot link to the...
Registering a unit Operating additional
handsets
Additional handsets
Up to 6 handsets can be registered to
the base unit.
Important:
L See page 6 for information on the
available model.
Registering a handset to a
base unit
unit, register the handset.
Handset:
{MENU} i {#}{1}{3}{0}
Base unit:
Press and hold {LOCATOR} for 4
seconds until the registration tone
sounds.
L If all registered handsets start
L The next step should be
completed within 90 seconds.
Handset:
beep sounds.
{OFF}
Note:
L While registering, "Base
registering" is displayed on all
L When you purchase an additional
registration.
Jan 18, 2018 | Panasonic Lands Phones
Panasonic kx-tg7120e extra hand set.
with the hand set on the base, unplug the power then try plugging it again.
Jul 02, 2008 | Panasonic KX-T7730 Corded Phone
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
I've repaired thousands of these kx-tga400b phones and we have the only improved keypad that eliminates the common keypad problems for good.
Does the cordless phone have a 3 in the top right corner after it registers to 3? If so, then it is registering correctly. If it THEN consistently says "invalid, please register" there is definitely a problem with the main circuit board and it's not at all common. I've seen a few of these but it's a rare problem. We can fix it but I'm not sure how much luck you would have with any other repair facilities.
If you have the problem intermittently it's probably a bad RF module. That's a much more common issue.
Feb 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
Lands Phones Logo
95 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
