I have direct tv service , i can not find the code to program the direct remote to make the tv work.
ASTAR LCD TV remote code for directv: 11531, 11548, 11738
The 11738 worked for me!
Code 807 with a philips universal remote , menu in my tv is accessible on front panel of tv(ltv-2601)
When you are ready to put the code in, press the channel up button slowly as if you are channel surfing, when the TV turns off, that is your code # and continue with the rest of the steps.
NO POWER
Try Philips TV Brand codes - Some important functions work with Philips codes - I am trying to get the "Menu" feature working. - Good Luck
SOURCE: need the code so that I can program my Direct TV
I just checked online at DirecTV and searched your Astar TV. This is the result I got...
"There is no setup code indicated for your product.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
How do i find out what is the code for a astar tv so i can use my cable companys remote
I use the TV remote to turn it on, and the TV Carrier remote to turn channels and volume. They said the TV was too new to have an acceptable code. 2 years old. same problem I guess need an answer too.
in reply to the latest help. Thanks, I cannot get my TV to turn on with the old remote to continue on the new remote~
my code to the t.v. is not working.....................
i have a astar tv brand .and i cant find the code for it. mi tv is a LVT-32HBG
i just got a astar 3001 from my job but i need the remote code can anyone help
needable code
hgfj gfujhgf ujhgfuhjgfvv j
