Choke it & it runs a bit, then falls flat. after several times of that, when starting, (choke it) it acc wide open 2-3 sec quits
SOURCE: no acceleration
I'd be checking fuel flow. Usually if you have to choke or squeeze a primer bulb to keep it going, the motor isn't getting enough fuel. Check all fuel lines and connections are air tight, then if problem persists, investigate fuel pump.
A good carburettor cleanout and new carb overhaul kit wont hurt either.
SOURCE: Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
SOURCE: starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
SOURCE: 2004 Honda Shadow Aero stalls
There seems to be low gas level in the float chamber of the carburator.
Clean the carburator and check the float level and reset.
With the choke 'on' and if you hit the throttle it will die because there is a restriction of the air flow to the carburator.
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
