Question about GE Kitchen Ranges
I HAVE A GE oven XL44. I CANT REMEMBER WHEN I PURCHASED IT. iT MIGHT HAVE BEEN IN 1995 OR EVEN SOONER. wE BOUGHT IT BRAND NEW.
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: GE XL44 gas oven
Starfish, remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle where you cant get at them. If you have trouble you can remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. Here's a little trouble shooting schem. Catriver...post back.
Posted on Jan 20, 2007
Anonymous
  • 4 Answers
SOURCE: GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Posted on May 18, 2007
Anonymous
SOURCE: oven
Same here, my wife freaked cause Christmas turkey took 6hrs.
I read somewhere that its internal thermostat. GE should offer to look into this seemingly wide spread problem
Posted on Jan 01, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
Anonymous
  • 70 Answers
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Posted on Feb 26, 2009
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2010 | GE Ovens
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
I have GE XL44 how do I lightthe oven pilot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101 .
Jan 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
MISSING PART OF MY XL44 OVEN
Hello, ammar738
Welcome to Fixya,
YOU SAID, YOU WANT TO BUY OVEN SAFETY VALVE, DUAL TYPE. BUT THE PROBLEM IT IS NOT IN MY COUNTRY (YEMEN) FORM WHERE I CAN BUY IT? INF: GE XL44 MODEL NO.JGBP28BEA2WH PLEASE HELP.
Below is the web site of one of our sponsors.
I'm pretty sure you can buy it online from them and have them mail or ship it to you. So tell them you pay the shipping.
Give them a try.
Let me know that you are successful
If not I'll find someone who will ship to you. If you have the part number it may help me search if these
people will not ship to you.
Parts house
www.RepairClinic.com
Huuum
Please remember to leave a rating when you are done.
Shookran
Oct 06, 2008 | GE JGBP24 Gas Kitchen Range
GE Spectra XL44
Easy to install you just have to remove the racks and the bottom of the oven. Call a local appliance store with the model # and ask for the ignitor.
Sep 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
