SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer does not recognize the M2 micro memory stick san disk
I have plugged in the micro mate mobile and windows asks me to insert a volume into the drive. I have already done that yet it does not read. Yet when I put the m2 card into my phone it does read.
  • Anonymous May 11, 2010
    Did you put a password on your m2 card..? If so unlock the pass from ur phone and then try.
Anonymous
Level 3:
President:
  • Master 287 Answers
  • Posted on Jan 14, 2010
Anonymous
Master
Level 3:
President:
Answers
287
Questions
0
Helped
105077
Points
1292
1. It means your computer is not able to access your phone!
2. Memory card seems to be working properly!
3. Try to reinstall the phone driver software on your computer.
4. Restart the system and check again!
please rate this advice if it helps...tc! :)
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Aug 30, 2009
Anonymous
Expert
Level 2:
Answers
43
Questions
12
Helped
16284
Points
110
Do this manually as it asks to insert a volume go to browse then go to ur program files->micro mate..->drivers or modem then press ok and then next it will install the modem automatically.
Where do i insert my phone memory?
would it not of been easer to use ur usb sony ericson lead straight from comp to ur phone soon as u plug it in windows instalation wizard will automatically connect it to ur computer it normally shows in my computer file as removable file E hope this helps
WONT BE RECOGNIZED BY MY COMPUTER SIEMENS FUJITSU (WINDOWS XP SP3)
Try the device in some other USB port on your computer.
Try the device in some other computer.
How to insert sandisk memory stick micro 1gb to computer?
Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
1helpful
My san disk m2 2gb memory chip makes my sony ericsson w205 phone freeze up but when i take it out th phone works fine.
this is a common problem for most of the phones you just insert the 1 gb card which was given to you with the phone
1helpful
2answers
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
My sandisk m2 does not get regognised on my mobile phone.
You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
Have a great day!
2answers
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
2answers
Computer won't read memory stick
SCMG - You won't be inserting it into your modem. But if the card fits snuggly and it seems to fit right, then you're probably where you need to be.
For all of you - it may be easier to connect the camera directly to the computer to download the pictures. All cameras come with the appropriate cable to connect the camera to a USB port. All you need to do is make the connection and then put the camera into "review" mode to view the pictures and Windows should automatically see the camera and ask if you want to download the pictures off of it.
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
