i
ifowodo precious mamuzo Posted on Jul 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A KONICA MINOLTA 190F COPIER PLS DIRECT ME ON HOW TO COUPLE THE DRUM ITSELF TO THE HOLDER
ADMIN Andrew
Level 3:
Top Expert:
  • Konica Minolta Master 66,931 Answers
  • Posted on Oct 06, 2023
ADMIN Andrew
Level 3:
Top Expert:
Answers
66931
Questions
Helped
5081186
Points
379583
Please refer to the service manuals and this.
Replacing a Drum Unit
Konica Minolta Manuals
https://manuals.konicaminolta.eu > contents
After Drum Unit replacement step 1 has been completed, check that the red-circled lock is located at the position indicated by a dashed line, then execute step ...
Konica Minolta REGIUS 190 Service Manual
ManualsLib
https://www.manualslib.com > ... > REGIUS 190
View and Download Konica Minolta REGIUS 190 service manual online. REGIUS 190 medical equipment pdf manual download. Also for: Dd-941.
Konica Minolta - Regius 190 Community, Manuals and ...
MedWrench
https://www.medwrench.com > equipment > konica-m...
Konica Minolta - Regius 190 by Konica Minolta. Konica Minolta - Regius 190. Forums ... Regius 190 Service Manual. SERVICE COMPANIESView All Computed Radiography ...
Konica Minolta Regius 190 (DD 941) Service Manual
Internet Archive
https://archive.org > details > manual_Konica_Minolta...
May 20, 2020 - KONICA MINOLTA. DIRECT DIGITIZER. REGIUS MODEL 190. (DD-941). SERVICE MANUAL. KONICA MINOLTA MEDICAL & GRAPHIC, INC.
..https://www.youtube.com/watch?v=lqfANSFl6Io
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 02, 2008
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Anonymous
  • 589 Answers
  • Posted on Feb 10, 2008
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Anonymous
  • 145 Answers
  • Posted on Dec 03, 2008
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Anonymous
  • 167 Answers
  • Posted on Feb 17, 2009
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Anonymous
  • 3 Answers
  • Posted on Mar 19, 2009
SOURCE: Konica Minolta copier model C252 code C6102 any idea
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
How do I rest a drum on konica minolta C554e
Then the drum you replace is not new there is a chip on it which tell the copier its new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
When I make color copies the output copies are black&awhile pls help
I suggest checking the printer setup on your computer to determine if the default is black/white. On my Windows 10 computer, the color printer default can be changed between color and b/w.
My konica minolta c353 the screen is not displaying
See if you can get a new control panel.
1helpful
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum unit replacement steps
Is the drum not part of the toner? Usually they are in a unit that slides into place but if not you may need to call an engineer to have a look
How do I change a Drum Cartridge in a Konica Minolta Fax 2900 / Fax 3900?
toner and drum are separate the toner attaches to the drum unit.
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Sc29-08 konica minolta
Magenta drum sensor remove the magenta drum and clean the small sensor the seats behind the drum front of drum small silver looking device with a very very small square opening. use brush or air.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
