Moen Chateau Loop-Handle Kitchen Faucet with Side Spray .... Logo
Posted on Aug 30, 2009
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced the faucet with a new facet and all is working fine. My Moen faucet was only 2 years old. Has anyone seen such a problem please? I'm thinking it's a mechanical problem in the faucet.
  • Anonymous Mar 24, 2014
    faucets does not turn off completely until 3 seconds after knob is off
David Burk
Level 1:
Scholar:
  • Contributor 49 Answers
  • Posted on Sep 03, 2009
 David Burk
Contributor
Level 1:
Scholar:
Answers
49
Questions
0
Helped
28609
Points
66
Wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
2helpful
2answers
Cold water flow is slow and handle is starting to get a little stiff to raise and lower - what is wrong and how can it be fixed? Moen M7800 Kitchen faucet
Not sure whether you are aware or not but most times, if you call moen with your model number and explain the problem your having, they will usually send you (free of charge-lifetime warranty) the part with instructions on repairing it along with it. You may have the 7800 series, but there are 3 or 4 different models if you check their site, and can identify the actual model, they will send you repair parts. Tell them you bought it ? years ago, and don't have the receipt, if they even ask.
try this link, if no luck, get back to me.
http://www.moen.com/replacement-parts
Why did my moen faucet stop working? I have water flow throughout the house but the flow at the kitchen faucet just suddenly stopped!
Rubber gasket on the water shut off valve under the sink has come off and traveled up into the faucet. It's pretty difficult to get it out. If you have access to an air compressor you may get lucky by taking the faucet completely off the sink and blowing air back from the faucet outlet back into the internal piping to dislodge the rubber piece. If that doesn't work, or you can't use the air compressor method, then it's a trip to the hardware store for a new faucet.
2helpful
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
3helpful
2answers
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
1helpful
My moen kitchen faucet wouldnt let me turn on the hot water for a day and now suddenly quit working all together. Can I fix this?
Just need to replace the cartridge. It happens....might be fun trying to get that one out though with the way it stopped working.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
