Plug the Equallizer into the tape in and out of the Fisher. Any tape decks go into the Realistic. The Tuner simply goes into the the tuner socket of the amp.
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment. When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR - --------- Video output - yellow. Audio output - left and right - red & white.
DVD -------- Video input - yellow. Audio input - left and right - red & white.
========================================= Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR.
However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc.
DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
