Have mitsu model # ws-65813 wont turn on
have harmony 880 remote 1 touch sat reciever stereo reciever and tv all come on at once when i pushed 1 touch all came on except tv the green timer light only came on and blinking fast for over 1 day now did this 3 times in last 3 weeks but tv eventually came on but not this time that is connected to surge protect tv never did this b4 i got harmony remote can someone help
Same thing, I tried to turn the tv on and the green light came on but the tv was black then the light started blinking. It would go off for a few seconds then start blinking again. I tried pulling the plug for a while but when I plugged it back in it started blinking again. I tried the reset button but now it won't stop blinking, it's been blinking for 3 hours.
WS-65813 Mitsubishi Same problem with flashing light wont reset used to reset now only flashes tried to reset with pulling plug for 24 hrs reset circuit is not working as per all other people with this mits problem Dont want to give up this great crt projector
Please help
[email protected]
There are 4 caps that need to be replaced. http://chrisandnat.com/projects/blinkingtv/blink.htm
SOURCE: have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
