Washer makes a nasty noise after washer is filled like a high pitched noise. Washer does not spin on the agitate or spin cycle.
This could be the coupling for the motor/transmission.
follows are instructions for removing the cabinet:
Now on the front of the base, you will see the pump. This is held on with two clips, Pop these off and pull the pump straight off the motor. The motor has two clips on it as well, (remove any screws if they are there, some have them, some don't) and pull the clips away. The motor will want to fall. Keep a firm steady hand under it to prevent damage to floor or motor.
Now you have access to most of the parts.
Look on the back of the motor and see if you see a little rubber disk with 6 holes. There is a three pronged connection on the motor as well as the transmission. If this coupler is not broken, you may have a bad transmission. To check for a bad transmission, take something that you can place over one of the prongs on the connection, and spin that first clockwise and note what the agitator does. Now spin it counterclockwise and see if the basket inside the tub starts to spin. If nothing happens either way, you probably have a bad transmission. If you get action from the transmission, then you just need the coupler, which you can get one at a local appliance parts store. Replace the broken parts and replace motor/pump assy.
Hope this helps :)
Joe
Replace the direct drive coupling between the motor and transmission.Open the control console to remove the washer cabinet. Remove the motor,replace the drive coupling. Re-install the motor. Replace the cabinet. Agitate and spin .
whirlpool ultimateII washer, 4 years old
Please provide: Brand, how old is the appliance, what 'weird' issues you had with the appliance before the failure appears.
