Question about MTX HTB1 System
Not sure i have properly connected to sony str dg600
I am not getting the sound quality or volume from all the speakers including the sub........both manuals are confusing as to what cable/wire plugs into what.......can you give me some direction on the connections.?..thanks
  • Mikey2323 Dec 05, 2007
    yes my receiver is the SONY STR DG600..thank you
  • Mikey2323 Dec 06, 2007
    can you blow up your diagrams any more..hard to read..also second diagram appears to have second illustration missing?
  • 1,113 Answers
Can you please tell us what you are connecting the "HTB1" to?
Posted on Dec 05, 2007
  • 6 more comments
  • Soulvisitor
    Soulvisitor Dec 05, 2007
    The top bit is cut off and only reads sony str...
  • Soulvisitor
    Soulvisitor Dec 06, 2007
  • Soulvisitor
    your amp puts out 7.1 ( 7 speakers plus subwoofer)
    your hbx1 is only 5.1 (5 speakers plus a sub)
    you need a rca y adaptor to run your subwoofer ie two plugs into 1 plug
    Not ver artistic but does this help you?
  • Soulvisitor
    all cables (except my yellow sub on) go from amp to speakers directly
  • Soulvisitor
    should read (yellow sub one)
  • Soulvisitor
    Better revised more artistic and correct
  • Soulvisitor
    no need for 2nd diagram leads go direct to speakers as labeled, centre front speaker to centre front terminal, left and right front to front a, surround to left and right rear speaker and t yellow one whitch goes to/from subwoofer via rca y lead, will not allow larger
  • Soulvisitor
    Soulvisitor Dec 07, 2007
    is this bigger?
6ya staff
SOURCE:
How do I connect my hct HSP 501 subwoofer to tv
The cheapest way of connecting your flat screen and speakers is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud. This will connect to the HCT's stereo line in socket labelled "2CH Input".
24200ec8-8a1b-44d7-923d-797f2146302c.jpgI
don't know if you'll get sound out of all speakers or just the front two and sub though. That depends entirely if the HCT is smart enough to make a stereo signal play all round.
Be aware; some TVs have a separate volume control for the headphone level. It's buried in the menus.
If you want the best quality, or there's no headphone jack on your TV, then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a speakers. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling
You then need a couple of connecting cables: An optical lead from TV to the box, and the stereo phono lead.
When using Optical, the TV's volume control has no effect at all on the volume going out via the cable. You have to use the volume control on the speakers. Does the HCT have a volume control? If not, don't waste your time with them. Go buy a soundbar and use that instead.
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 13, 2014 | Televison & Video
Klh powered sub woofer
Low level inputs are designed to take signals directly from an amplifier's "sub out" connections. That way the KLH amplifier will use those signals to produce sound and the volume can be balanced between the main amplifier and the sub amplifier using the sub's volume controls. Depending on your amplifier and sub, that is the best way to connect them. However, be careful running the RCA cables since the low levels are more subject to interference. Keep the runs as short as possible and use high quality shielded cables for the interconnects.
Aug 26, 2014 | Audio Players & Recorders
Hello- I have my denon receiver connected to my tv with 2 front speaker,2 surround and center channel along with the sub. The problem is that when i play a blue ray, all my speakers produce sound including...
I need to know the quality of the speakers on the TV. Try unplugging it from the speakers on the TV and plug it into the souround sound speakers only and see if it plays differently. Double check your sourround sound and makes sure you did not reverse a wire.
DCBdigital.com
Feb 28, 2014 | Audio Players & Recorders
Hi, My friend left me his Z-2300 sub but lost the speakers that go along with the system. What speakers are the best replacement for the sub? which dont involve me soldering any wires!
I don't know which would be best but my recommendation to you is go shop around on the internet or in stores and find some good quality 2.0 (2 speakers without a subwoofer) computer speakers. If the speakers don't already have RCA connections it is easy to find a 3.5mm to RCA cable connector. Let me know if you want me to clarify that....audio lingo is very confusing sometimes!
Nov 01, 2010 | Logitech Z-2300 Computer Speakers
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Mar 07, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Proper set up
Try to google the brand name and get the user's manual. Usually the extra cords plug into one of the other speakers and then one to the computer. Sound card could be an issue but I doubt it.
Dec 25, 2007 | Logitech X-540 Computer Speakers
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Connection to Laptop
Since the majority of laptops do not have multiple sound outputs you will need to buy a couple of headphone splitters. Plug the first Y splitter into the laptop headphone port and plug one of the input cables going to the speakers in one arm of the Y. Next, plug another Y splitter in the remaining arm of the first Y. This will provide you with the other two inputs that you need. Plug the remaining speaker cables into the other Y arms. From there it is simply controlling the speakers using the laptop volume and/or the speakers volume. You will not have fader control on a 3.1 or 5.1 speaker system but it will give you what you are looking for. I have this same configuration at my office using an IBM laptop and a 5.1 surround sound system. Good luck. JC
Jul 29, 2006 | Compaq PS330 Computer Speakers
MTX HTB1 System Logo
506 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
