How do i get to the batteries to change them on braun shaver model #8585?
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
manual
No blue light when plugged in. Lights on units do not come on
