Ryobi 3-piece 18V Drill / Circular Saw / Light Combo Tool Sets Logo
Anonymous Posted on Aug 29, 2009
Plug battery in and lights don't go on
The other battery works fine. I've checked voltage and voltage is around 3 volts lower than good battery. It does have power left, but pointless if I can't charge it. I can also use it with the tools (flashlight works with it). I pulled the battery apart and spread the contacts a bit and wiggle it in the charger all to no avail. I also pulled the charger apart and taped the charging contacts directly to the appropriate contact on the battery with no luck. I plugged it into the charger after 1 1/2 hours of sitting (immediately after charging the good battery) and the red charge light turned on but was on for less than 30 minutes (walked away then came back later). The charger was very warm to the touch when I unplugged it. The voltage didn't move at all after having it plugged in for that few minutes. Battery is a Ryobi One+ 18V BD0529 (also see P100 in red lettering on bottom of battery).
Mark
Level 3:
President:
  • Master 704 Answers
  • Posted on Sep 20, 2009
Mark
Master
Level 3:
President:
Answers
704
Questions
0
Helped
592466
Points
2820
The battery is failing and is starting to degrade. If you can't get it to take a full charge, you might want to mark it for use in your flashlight only, but eventually, the battery won't take any charge and you'll have to replace it.
The good news is the the Ryobi battery tools have the lowest cost of rechargeable batteries in the marketplace. I believe you can purchase a 2 pack at Home Depot for under $40.00 which is very inexpensive for two (2) Ni-Cad batteries.
If you battery is from a new tool set, just simply contact Ryobi Customer Service and they'll address the problem with a replacement. If the batteries are ones you've been using for awhile, then go for the replacement.
NiCad batteries should be used until the tool slows down to the point where you can't use it. Then remove the battery from the tool and allow it to cool down for about 15-20 minutes before placing it in the charger. This will provide the maximum working life for your batteries.
When you use a battery powered tool, the battery gets warm/hot as it discharges, and then it gets heated up during the recharging process, so letting it cool down after using it, will prolong the useful life of that battery.
Hope you find this Very Helpful and best regards!
Testimonial: "Thanks for confirming my thoughts. I hadn't thought of letting the batteries cool down between discharge/recharge cycles."
Check gauge light comes on and voltmeter shows low voltage
start the car. if you have a volt meter at the battery you should have 13 to 14 volts while running. if not your alternator isnt working.
Battery is not charging and the speedometer is blank and not working but the bike is running fine after I jump start it
I can't help you with the speedometer as I have no idea about those things. I'm an old school biker and I work on old bikes that the dealer will no longer work on. But, here's how to check your charging system.
Here's how to check the charging system. To do this you need to fully charge the battery and you'll need a good Digital Volt Ohm Meter. Using the meter's function selector switch, set it to DC VOLTS with a range of 20 volts or greater. Connect the red meter lead to the positive battery post and the black meter lead to the negative battery post. Start the
engine and bring it to a high idle. After about a minute or so, your meter should read between 14.5 and 15.0 volts. Any lower than 14 volts, your battery will not be charged.
If you don't have the minimum voltage at the battery in the previous test, you need to check the
alternator to see if it's generating sufficient voltage. You'll have to follow the wires from your voltage regulator going to the lower left front of your engine until you come to a plug. Unplug the plug and look into the engine side of it. You'll see two metal contacts in the rubber plug. This is where you are going to test the voltage from your alternator. Since you'll be testing AC voltage, it makes no difference which meter lead goes into which contact, just one lead into each contact. Set your meter's function selector switch to AC VOLTS with a 50 volt or greater range. Start the engine and bring it to a high idle. Insert one meter lead into each of the metal contacts. Do not let the leads touch each other or the engine case or ground. Your meter should read at least 25 volts.
If you do not have the 25 volts from the alternator, your stator is bad and must be replaced. If you have 25 volts or more but not the 14 volt minimum at the battery, your voltage regulator is probably bad. Make sure you voltage regulator is properly grounded. Check the condition of the wire coming from the regulator going to the battery. This wire is usually larger in diameter than the other two going to the alternator.
Good Luck & Ride Safe
Steve
1helpful
I have replaced the battery, the bike starts fine, and runs fine. But, when iit is checked, the system is not charging the battery. voltage regulator has been replaced twice.
You need to check the charging system. To do this you need to fully charge the battery and you'll need a good Digital Volt Ohm Meter. Using the meter's function selector switch, set it to DC VOLTS with a range of 20 volts or greater. Connect the red meter lead to the positive battery post and the black meter lead to the negative battery post. Start the engine and bring it to a high idle. After about a minute or so, your meter should read between 14.5 and 15.0 volts. Any lower than 14 volts, your battery will not be charged.
Good Luck
Steve
1helpful
Just replaced the battery in my 06 Super Glide. Now the battery light will not go off?!?! Do you think the regulator is bad?
Well, let me begin with telling you that I don't know a lot about the newer bikes but there's nobody else here as far as I know. I've head some of the guys talking about having to "reset" the ECM when you take the battery out. It's a series of operations in which you turn the ignition switch on and off while pressing other controls on the bike. If you can find someone with an owner's manual it may have this procedure in it. If you want to check your charging system, here's how. These instructions may not be exactly right for your bike but close enough for you to figure out how to do it. If you need to check the charging system. To do this you need to fully charge the battery and you'll need a good Digital Volt Ohm Meter. Using the meter's function selector switch, set it to DC VOLTS with a range of 20 volts or greater. Connect the red meter lead to the positive battery post and the black meter lead to the negative battery post. Start the engine and bring it to a high idle. After about a minute or so, your meter should read between 14.5 and 15.0 volts. Any lower than 14 volts, your battery will not be charged.
Good Luck
Steve
2010 softail custom engine light keeps coming on and won;t charge
Your bike may differ a bit but this is how to check your charging system.
Good Luck
Steve
I have an harley flhtc 1984. my low beam light shuts off but when on i have a drain on the charging system. am i looking at a short
alternator to see if it's generating sufficient voltage. You'll have to follow the wires from your voltage regulator going to the lower left front of your engine until you come to a plug. Unplug the plug and look into the engine side of it. You'll see two metal contacts in the rubber plug. This is where you are going to test the voltage from your alternator. Since you'll be testing AC voltage, it makes no difference which meter lead goes into which contact, just one lead into each contact. Set your meter's function selector switch to AC VOLTS with a 50 volt or greater range. Start the engine and bring it to a high idle. Insert one meter lead into each of the metal contacts. Do not let the leads touch each other or the engine case or ground. Your meter should read at least 30 volts on a Big Twin, 25 volts on a Sportster.
Good Luck
Steve
Put new batt in bike, worked for a week then stalled, when I jump start bike it runs till I unhook cable bike dies. whats wroung
You didn't say what year or model bike you're working on but either way, I'd check the charging system. I'd also take the battery back where I bought it and have it checked. I've seen brand new batteries go bad. Have it checked just to make sure it is good. You need to have it "load tested", not just put a voltmeter on it. A voltmeter doesn't tell you the condition of the battery because the meter is designed not to put a load on the device you're checking. The starter puts a tremendous load on the battery and if it's got a shorted cell, the voltage will drop below 11 volts when trying to start the bike.
alternator to see if it's generating sufficient voltage. You'll have to follow the wires from your voltage regulator going to the lower left front of your engine until you come to a plug. Unplug the plug and look into the engine side of it. You'll see two metal contacts in the rubbber plug. This is where you are going to test the voltage from your alternator. Since you'll be testing AC voltage, it makes no difference which meter lead goes into which contact, just one lead into each contact. Set your meter's function selector switch to AC VOLTS with a 50 volt or greater range. Start the engine and bring it to a high idle. Insert one meter lead into each of the metal contacts. Do not let the leads touch each other or the engine case or ground. Your meter should read at least 25 volts is the bike is a Sportster, 30 if it's a Big Twin.
Good luck
Steve
1helpful
2answers
I have a Sony Bravia 32" LCD tv...my query is that if the tv will be suitable in 110voltage plug or we should change it to 220 volt?
try to check first the voltage requirements at the back of your tv it is printed there, but most of the tv models specially the lcd it is auto volts.
1helpful
I need to find out what the voltage output and the miliamp output is on a toro z4220 mower my battery keeps going dead i have replaced it once already Thank yoy
You should have around 13.1 volts at the battery as the engine runs. If its 12 volts or lower - check or replace the voltage regulator. To check the regulator, stop engine, remove regulator plug, get a ohm meter and put the black lead to any ground,and touch the red lead to all the terminals one by one on the voltage regulator - you should get 3 readings - one lower than the other. If you dont get any readings - the regulator is definitely bad
Don in Baltimore
2helpful
2answers
Elec problem between alternator and battery
Rest at ease the 14 volts will not hurt your system idealy your alt will charge at around 14 to 14,5 volts at the alternator and probably have a slightly lower charge rate at your battery at around 14 to 13.5 at the battery this is completely normal
Top Ryobi Saws Experts
john h
NOEL
NOEL
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
