Philips GoGear SA5285/37  Digital Media Player Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Playlists How do I add playlists to my Phillips SA3285 player?
Anonymous
Level 2:
Scholar:
  • Expert 72 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
72
Questions
0
Helped
19794
Points
240
You can add it by connecting your device to the pc, open either real player or windows media player and there is an option in both the softwares to synchronize the device to pc. after synchronizing, add them to your device. the playlists you created in your pc will be exactly in your device then
How can I delete songs from my iPod playlist?
If you want to manage songs on your iPod's playlist, then you can count on this iTransfer tool. It helps you manage playlists of the iOS devices/iTunes. You could add music to playlists, export/rename/delete the playlists.
Leawo iTransfer User Guide How to Manage Playlists of iPhone iTunes
2helpful
How to add a playlist??
There are two ways in which you can add a playlist....
1......by using your playlist via the player...
2......or by creating one using the computer....
First lets see the one using the player...all you have to do is go to the song navigate option...highligh the song that you wan to add to your playlist and then click the record button.you will be given two choices..one add to my playlist and two erase.....click the add to my playlist option and you will have the song added to you r playlist.....
second method is create a normal playlist using windows media player with the correct directories in the player and then copy the file to the player...
now when you press the menu button for a second or two in the songs menu...you will be displayed two choices....one file navigator and the other is playlists....
click the playlists option to access the playlists....
3helpful
2answers
I have a Gogear aria black phillips 8bg mp3 player..playlist help
This is a good little player (although I don't kow why tey dont' include the actual manual for it)
It took me a bit BUT I found the manual online:
http://www.p4c.philips.com/files/s/sa1ara08k_97/sa1ara08k_97_dfu_eng.pdf
After you've created and saved your playlists...then clear the sync pane.
Then on the far left where all your playlist names are...highlight the ones you want and drag them into the sync menu. then click "Start sync".
After it's done I promise you all your playlists will be there complete with the music you added to the list
1helpful
I can't add tracks to any of the playlists that I've created!
Are you creating playlists with Musicmatch or are you creating them directly on the DJ?
Let's say you have a playlist on your DJ and want to add a track to it. First, play the playlist. While it is playing, go to Music Library, find the track you want to add, select it with the thumbwheel, one of your choices in the menu that comes up is "Add to Selected". Select "Add to Selected". Now when the DJ reverts back to the screen showing the track being played. Hit the thumbwheel twice. A menu comes up. Select "Save as Playlist". Name it. Then delete your previous version of the playlist. Your new version will include the track (or tracks) you added.
Okay, that answered your specific question, but let me tell you it is much easier to build and organize, and yes, edit and/or add to your playlists from musicmatch.
After loading musicmatch, up near the top is a button called playlists. On its menu, select Playlist Manager. The window that opens has buttons that will let you create new playlists or modify old ones. You can dock your dj and edit the playlists on it from here or build playlists and then Send them to Portable Device (your DJ) Fairly easy.
Phillips 4gb Go gear playlists
The Playlist feature only creates a "Playlist on the Go" from the player itself - you cannot transfer playlists to the player from your computer. A real let down, I know.
-Tha Mp3 Doctor
1helpful
Philips GoGear SA3245 - Playlists Not Showing Up on Player
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
15helpful
7answers
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
1helpful
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
Can't add playlists
go to computer than click on Sansa e260
- Click on PPI NAND
- Click on PLAYLISTS
- Create a new FOLDER
- Give your playlist a name
- than put the music in it.
How to create multiple playslists for M250
Alright, well if you are adding songs to your MP3 player by using Windows Media Player, you can create playlists there, sort the songs into what playlists you want them in, right click the playlist, and click "add to sync list".
If you are manually copying and pasting the music into the mp3 player (that's how I do it) it's a little less obvious... For me there are three main folders: Music, Playlists, and RECORD. So we want to go to the playlists folder. In there, assuming you have at least one playlist already, you can copy and paste it, naming it something else and changing its properties as you see fit (right click -> properties). To add songs to the playlist, you go to it's properties, and under the references tab, drag the music files from wherever you have them stored and drop them in the references tab. This won't move your music, it'll just add them to the playlist. and.... guess that's about it. Hopefully that helped.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
