Hi, E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work. Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store. Good Luck.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!! rate me!!
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
It turns out that the problem was the batteries. I put some good ones that I had in the camera and it started working just fine. Even though the others were showing that they at least partially working, maybe just not enough juice to really work. Anyway, with just about any problem - try new batteries first and see if there is any change or improvement.
I tried alkaline batteries in this camera and it would only work for a few pictures, then it would go unstable and do unpredictable things. The lithium batterys also caused problems like the ones you described. As a last resort I found that there was a ni-mh battery for this camera. I could not find this accessory. I purchase some batteries and charger then installed them into camera. reset the camera using the reset function, then tested camera. It now works correctly and consistantly takes good pictures. If the camera does not work with the ni-mh batteries it might be damaged or bad.
