Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
I have a Kenmore oven with no directions. We cannot get the broiler to work. Can you tell us how to do turn it on? billiejack69@hotmail.com
    President:
  • 704 Answers
Here's the manual for your oven, based on the model number you provided.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0522659.pdf
If this isn't your oven, use the following link to enter in your model number to get the correct manual, free.
http://www.managemyhome.com/mmh/ (click on the manual tab)
Hope you find this Very Helpful and best regards!
Here's how to use the broil function of your wall oven:
Press the BROIL pad. (This will
automatically set HI Broil).
lb. While the set indicator is flashing
in the display, press the BROIL
pad again if you prefer to use
Lo Broil. Use Lo Broil to cook
foods such as poultry or thick
cuts of meat thoroughly without
over-browning them.
2. Press the START pad.
3. When broiling is finished, press
the CLEAR/OFF pad.
Posted on Aug 29, 2009
6ya staff
SOURCE:
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Oven will not light but broiler works. Ignition Module turns red when you turn on oven but no fire
there is a small bathtub shaped can that the gas line goes into under the broiler this releases the gas to the ignitor module replace it
Apr 21, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My Kenmore oven wont ignite. The broiler works
The problem is your bake ignitor. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
Feb 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
198 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
