HP Pavilion Elite M9150F Desktop PC Logo
Anonymous Posted on Aug 28, 2009
My S Video from laptop works with TV however no sound on TV
My laptop still controls the sound if I get a S Video (from computer) to RCA cable will that enable me to control the sound and hear it from my TV? Thank You
  • Anonymous Aug 28, 2009
    Cancel this was posted under the wrong product I have a Dell Inspiron 6000 with this problem.
Anonymous
Level 3:
  • Master 336 Answers
  • Posted on Aug 28, 2009
Anonymous
Master
Level 3:
Answers
336
Questions
Helped
169864
Points
1139
No The s-vid is only video. The s-vid to rca adapter will have a yellow rca plug, and yellow is always video. You need a mini headphone to rca adapter for the sound. Attach the mini headphone jack to the speaker out on computer and run rca cable(s) to the audio in on the tv.
Fred McCoy
Level 2:
  • Expert 380 Answers
Fred McCoy
Expert
Level 2:
Answers
380
Questions
0
Helped
150601
Points
948
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
S-Video Connecting Laptop and PC
The best way is via the VGA connector on the computer and by connecting the Audio out on the back of the computer to the RCA sockets on your TV. You will need a 3.5 mm jack to stereo RCA cable for the audio.
1helpful
2answers
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
I bought a cable that plugs into my laptops monitor outlet and turns the other end into S video and RCA jacks. i Go to my control panel and try to set my tv as a monitor and it makes a couple of buzzing...
there is a piece of hardware that you will need that goes inbetween the laptop and t.v. im not sure what its called but you can call any computer store and they will tell you what it is
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
2answers
How do I connect my laptop to my TV wiyh a VGA
do you have a VGA input on the TV?
If not, you need a PC to TV converter.
Link Here:
http://www.geeks.com/details.asp?invtid=ITV-900&cat=VCD
This ITV-900 is a one piece PC to TV Converter that lets you show computer presentations, play games and watch DVDs on TV. It converts your computer's VGA signal to your TV's S-Video and video output signal!
The PC to TV converter supports up to 1024 x 768 resolutions, NTSC/PAL television system, auto fine tuning and more! This ITV-900 is compact, portable and easy to use!
3answers
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
1helpful
I'd like to watch videos from my laptop on my tv
You will also need a 3.5 MM jack to RCA for your sound as well as a short stereo RCA cable. SVideo only transmits video, you need to send sound to your TV as well. Radio Shack sells these. They can also be used to send audio from an MP3 player to your TV or from your computer to an external home theatre system for greater sound quality. Do not confuse this with a 3.5mm to A/V RCA cable. That was designed to allow ipods to send A/V to a TV and you will be paying for more inputs then you need. The headphone jack of your laptop will usually send Left and right audio (mine has 2, the first sends front Left and Right, and the 2nd sends rear left and right, center and subwoofer. Most people only use front left and right so all the others are bundled into the second).
PS. The 3.5mm to RCA is usually sold with Female RCA endings so you will need a male RCA cable to connect to the RCA ports on your TV. I have a 20' RCA cable running from my Mac to my Amplifier to play my itunes on my Theatre speakers, but if you don't need that much a 3-6' RCA should work fine and would be a lot cheaper. On the mac side, I have the 3.5mm to Stereo RCA adapter hooked to my Audio out jack on the back. This is the cheapest option vs getting a PCMCIA TV tuner card which can set you back at least $80-$100, if not more. Tell the people at RadioShack what you are trying to do and they should be able to find the exact products I am talking about. The adapter should be about $5-10 and the cable should run you another 5 or so bucks as well.
2answers
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
1helpful
Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
