No sound in OS Vista x86 and win 7 x86 with P5VD2-MX motherboard or very slow sound.
Hi again,
I've just run a check, and Asus don't have driver support for win7 on the P5VD2-MX, not sure if they ever will. Though they do have the drivers for Vista (32Bit),
You can download them from here:
http://support.asus.com/download/download.aspx
Just type in the model number in the top left corner, select the correct board, then select your OS, then away you go.
Hope that helps.
Regards
Tim
My own experience tells you to get to www.funkinyes.com to buy, works well and is genuine, there is that it took me a little money, worth buying, recommended to you want to help you.
Dear Tim,
You don't mention if you have tried this out! Does the 32-bit Vista driver really work in Win 7 Home Premium, or are you guessing?
I have down loaded the Vista 64-bit driver, and I can tell you that it doesnt work with Win 7 Home Premium (64-Bit). I trying to find Another solution!
Regards
Mats
Hi there. Have you always used this mobo with Vista or Win7? Tim
