If it is the factory system that needs to be reset, unfortunately you will need a Ford IDS, which most large shops have or your local Ford dealer. If it is the aftermarket alarm system that needs resetting, then you need and authorized dealer of that alarm system.
Ford products are sensitive to changes in Battery voltage. The system views low Voltage as an attempted theft and makes the Alarm go off.
Remove the Battery, return it with a full charge or new Battery. Some other symptoms would be slow cranking or clicking like a dead battery. The Antitheft reduces starter Voltage to around 7 Volts making starting nearly impossible.
Please rate my info. If all else fails, the Identity in the car memory may no longer match the identity on the car keys. You would need to have a Dealer rematch the keys to the car.
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this: Remove the key from the ignition disconnect the negative battery terminal put the key back in and turn to ON exit the truck and leave door open reconnect the battery terminal get in and leave door open, if the alarm horn stays off it should start.
tMy 2004 Ford Explorer ran today for about 100 miles I turned it off and it wouldn,t start. It turns over and almost starts. We had the air conditioner on during the 100 miles.
Is the engine turning over? When you turn the key to the on position, does it behave normally? IE, do the battery and airbag and other lights come on when you turn the key to on position?
