Question about eMachines Computers & Internet
How do you backup data on a eMachines etower 566 ir?
5 Suggested Answers
6ya staff
SOURCE:
Harisk Karameh
  • 68 Answers
SOURCE: EMACHINES ETOWER 633IDS FULL SYSTEM RESTORE?
If it is in original configuration system restore would be on D: drive partition
Posted on Mar 10, 2009
Francis Mason
  • 87 Answers
SOURCE: unable to install , maybe my computer is too
There are a few reasons why a program will not install. I will try to help you resolve each.
1. Lack of privileges. Do you have local Administrator rights to install software? If not, can you login as the local Administrator to install the software?
2. Do you have the minimum Operating System requirements for the software? If you are running an old Operating System (Windows 95/98/2000/ME) then many new software programs will not install. If you are running at least WIndows XP or Vista, then you may need to install the latest service pack depending how new your utility software is.
3. On the flip side the Utility software may be too "old" for the Operating System! If this is possible, look on the web for a new version that is supported by your Operating System.
4. Do you have the minimum Hardware requirements? Do you have the minimum Memory/Disk Space for the software to install/operate?
5. Expired software. Is this software a time limited evaluation that is now expired? If so, this should be apparent when you attempt the install.
Use the above ideas to find the reason/solution to the problem you are having. :-)
Posted on Nov 19, 2009
muntejaya
Muntejaya Ginting
  • 10421 Answers
SOURCE: I forgot to remove input
Hi, First, check your power supply fuse for damage and switch the power to standard. Disconnect power supply output port and check your output voltage. If nothing abnormal, turn off power supply, connect the output and turn it on to check the power on your PC
Regards,
Posted on Dec 14, 2010
morse_rdband
Pablo McNealy
  • 88 Answers
SOURCE: need product key for emachine etower 400i3. I
Go to Windows 10 Key Sale Store (http://www.windows10keysale.com) . I must thank them for their great product key and warm customer service as well as quick delivery of email. This is the best online purchasing experience Ihad ever! You also can buy the product key here and activate you operating system in a short time.
Posted on Apr 18, 2016
What is the three digit code for DISH on a Sylvania LC195SLX
Hi, my name is Cheri Torres and I work with DISH Network Customer service. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for each of our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information helps and if you have any other questions please let me know!
Remotes models Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 632, 569, 566, 671, 733, 515, 568, 764.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 569, 566, 536, 733, 672, 660.
4.0 and 4.4 IR/UHF remotes - codes 733, 569, 566, 632, 764, 664.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 733, 569, 566, 654, 672, 632, 764.
20.0 IR and 21.0 IR/UHF remotes - codes 733, 672, 777, 566, 764, 527.
Instructions for addressing the remote to the TV
1. Press and hold down the TV mode button until all the mode buttons light up red.
2. Enter the 3 digit code using the keypad.
3. Press the pound(#) button once.
4. Test the functionality of the TV.
Oct 17, 2011 | Sylvania LC195SLX LCD TV
I forgot to remove input power supply of etower. Whilst emachines etower power supply was still on, i accidently moved the voltage selection switch to a higher voltage. There was big bang and fire happend...
Regards,
Dec 14, 2010 | E-Machines etower 566i PC Desktop
I need emachine etower 600is intel processor
The eMachines eTower 600is uses an Intel Celeron III processor that operates at a maximum frequency rate of 600MegaHertz. (600MHz)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=eTower%20Series&model=eTower_600is
The Intel Celeron 600 uses a Socket 370 processor socket.
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Coppermine-128.22_.28180_nm.29
There is a locking arm on the side of the Socket 370 processor socket, that is unlocked by easing the arm over to one side to clear a lock tab, then the arm is lifted up to remove the processor.
Example of a Socket 370 processor socket,
http://en.wikipedia.org/wiki/Socket_370
The eMachines eTower 600is uses an Intel 810 chipset, for the motherboard chipset.
[Chip and Chipset are slang terms used for Integrated Circuit, or IC]
The Intel 810 chipset, supports processors with a 66MegaHertz Front Side Bus. (66MHz FSB), or 100MHz FSB.
In an additional link, I will give a recommendation of where to buy an Intel Celeron 600, that uses a 66MHz FSB.
I'm not advertising for this place, it's just a place I have used, and have had good results.
Also information on the Intel 810 chipset.
You could also use an Intel Celeron 700MHz processor, but better still you could use an Intel Pentium III 933MHz processor.
Pentium's typically have Two times, the L2 cache that a comparable Celeron has.The more L2 cache a processor has, the faster it's going to process information.
I also know it will work because out in my shop I have an eMachines T1090, that has an Intel 810 chipset, uses a Socket 370 processor socket, and has an Intel Pentium III 933MHz processor in it.
(Made in 2001, and still works good to this day)
The Intel Pentium III 933MHz processor uses a 100MHz FSB.
The Intel 810 chipset supports processors that have either a 66MHz FSB, or a 100MHz FSB.
If you are not familiar with computer hardware technology, then I have just thrown a whole lot of information at you that is unfamiliar.
Should you like me to break down the information, I would be glad to. Just state so in a Comment.
Mar 22, 2010 | E-Machines etower 600is PC Desktop
Where do i find windows 98 disk for the emachine
try going to there web site look under drivers . that is a rather old os not sure there will be an support, you can always find old disc's at local thrift store....
Feb 01, 2010 | E-Machines etower 500is PC Desktop
Sound driver I NEED THE SOUND DRIVER FOR MY E MACHINE ETOWER 400i
see link below.
http://www.driver-download.net/emachines/other/etower-400i/
Nov 28, 2009 | E-Machines etower 400i PC Desktop
After etower shut down for some time it wil not start
It is possible that the power supply could be dead, I've seen this many times when people move their computers around.
Mar 25, 2009 | eMachines etower 466id PC Desktop
Mar 10, 2009 | E-Machines etower 633ids PC Desktop
Need assistance in locating drivers for an emachine id2 etower. i know its rather old but i am having trouble finding drivers.
hi there,
please try this link:-
not too clear on your system model or operating system type...
Apr 27, 2008 | Computers & Internet
Owners manual
Looking for Free Manuals?
Free Repair Manuals and Support.
Free help on all Products
www.Fixya.com/Etower+Manual
Nov 27, 2007 | E-Machines etower 333i PC Desktop
Computers & Internet Logo
19 people viewed this question
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
