If you lost your password/forgot what you set it to, you will have to factory/hard reset your router back to factory default settings and set everything back up again. Just make sure you keep your password somewhere safe so you don't lose it again.
To hard reset (Factory Reset) your router (The best method), use the following steps:
The following procedure will clear out the NVRAM and set your router back to default values:
- With the router powered on, press and hold the reset button on back of unit for 30 seconds
- Without releasing the reset button, unplug the unit and hold reset for another 30 seconds
- Plug the unit back in STILL holding the reset button a final 30 seconds.
This procedure should be done BEFORE and AFTER every firmware upgrade/downgrade.
Do not use configuration restore if you change firmware builds (different svn build numbers).
The default login for your router's control panel/settings manager is as follows:
Username: Not required /Admin/Administrator (Try all three. One should definitely work)
Password: admin (Case Sensitive)
Also the default access IP of WRT54G is 192.168.1.1 or 192.168.15.1 (Depending on version) so after you hard reset the router and get it booted back up, you should be able to access the router via:
http://192.168.1.1
http://192.168.15.1
I hope this helps. I know it's probably not the answer you wanted, but unfortunatly you won't be able to retrieve or change your password without having the password or hard resetting your router back to factory defaults and set it back up (Sometimes good to do anyway every once in a while).
Also, just as an extra tip/hint, I'm going to lead you in the direction to turn that $60 router into a $600 router (Theoretically speaking) just by using a custom firmware called DD-WRT which unlocks TONS of options and is faster and much more stable than the factory firmware.
You can find DD-WRT here:
http://www.dd-wrt.com
Enjoy!
Best Regards,
James
